Activity Forums Apple Final Cut Pro Legacy article on compressor 3 for 8-cores? qmaster?
  • article on compressor 3 for 8-cores? qmaster?
    Posted by Jack Nastowski on June 14, 2007 at 8:03 pm
    Does anyone know of a step by step manual or article on how to setup a MacPro to take advantage of all the processors by creating a cluster in qmaster?
    I unpacked my macpro and did some compressor encoding tests and was heart-wrenchingly depressed to find that it was taking longer then my three year old MacG5.
    Please help!
    Gary Adcock replied 19 years, 2 months ago 4 Members · 4 Replies
  • Mark Raudonis
    June 14, 2007 at 8:24 pm
    Apple has the Compressor manual on their site. It has a very detailed, step by step explanation of how to set up compressor for a cluster.
    Mark
  • Mark Maness
    June 14, 2007 at 9:00 pm
    Yeah, it does… BUT it is so detailed and takes so many side roads, you get lost.
    I’m still having difficulty setting it up properly. I’d love to have my Mac Pro and my G5 talking so that I could do large jobs over the weekend.
    Has anyone figured it out, yet?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Mark Raudonis
    June 15, 2007 at 4:54 am
    See my post about compressor above…. 30 + systems and churning. When it works, it’s awesome. We have experienced some random hangs that we don’t quite understand. On the other hand, if it only takes you 6 minutes to do what took hours previously, then you can just try it again and chances are, it will work.
    Mark
  • Gary Adcock
    June 15, 2007 at 12:43 pm
    [JackNastowski] “Does anyone know of a step by step manual or article on how to setup a MacPro to take advantage of all the processors by creating a cluster in qmaster?”
    the quick question
    did you check the box to allow compressor to be part of a render? it is a dialog when you install !
    IF your not sure, reinstall the Q master Node engine from the extras folder on the installer disk this time check YES to the render engine install.
    reset the background processing in Compressor
    when you launch the batch monitor select the “cluster” rather than the machine itself.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
