Activity Forums Adobe Illustrator Artboard question
  • Artboard question
    Posted by Marcus Lovitt on May 30, 2011 at 4:37 am
    Hi everyone,
    I just received this from our printer:
    “Your illustrator data came without crop marks, and one art-board is horizontal while the other is vertical. Below you’ll find a 55x90mm template for you to use with your data. You’ll need to send us either both vertical (portrait) or both horizontal (landscape).”
    It’s a business card template. Can anyone give me simple instructions on how to do this (I’m relatively new to Illustrator).
    Cheers,
    Marcus
    Marcus Lovitt replied 15 years, 3 months ago 2 Members · 2 Replies
  • Scott Roberts
    May 31, 2011 at 1:19 am
    Sounds like you’re doing a two-sided business card. Make both sides horizontal, or vertical, so the printer knows the correct orientation.
    LittleBlackBird.net
    GraphicsDump.com
  • Marcus Lovitt
    May 31, 2011 at 6:23 am
    Hi there,
    Thanks. So is it simply a case of selecting all, doing a cut and paste to their template, then rotating using transform?
    Marcus
