  • Posted by Stig Olsen on October 21, 2013 at 9:25 am
    Im going to do an animation with some arrows following some lines of a body.
    When the arrows move from the feet and up the legs I want the arrows to bend as if they are following the lines of the body.
    Any suggestion?
    Stig
    Joseph W. bourke replied 12 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Joseph W. bourke
    October 21, 2013 at 3:14 pm
    I haven’t tried this before, but could you use the body graphic as a custom Displacement Map?
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Stig Olsen
    October 21, 2013 at 3:17 pm
    Hi Joseph,
    You can see what Im trying to achieve here – https://www.youtube.com/watch?v=RzHUsyZamgM
    Stig
  • Kevin Camp
    October 21, 2013 at 6:35 pm
    you’d create a path on a solid and use the stroke effect to animate the line, or create a path as a shape layer and use the stroke property and use trim paths to animate the line.
    then you can select the mask/path property and copy/paste it onto a layer that will be the arrow head. right click that layer and choose transform>auto orient and select along path. then adjust the timing to match the line.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Tudor “ted” jelescu
    October 22, 2013 at 7:00 am
    To get the arrows to follow the shape of the body I can think of 2 ways:
    1- 3d arrows following a path- Zaxwerks 3d Serpentine.
    2- animate an arrow flow on a flat layer, precompose and distort in 3d to follow the shape of the body using Free Form or FreeForm Pro.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Stig Olsen
    October 22, 2013 at 8:22 am
    Thank you,
    Kevin, I can have the arrows follow the line, but with your method I cant have the arrows bend to follow the curves of the body. like in 3D. Any suggestion?
    Stig
  • Jason Jantzen
    October 22, 2013 at 7:59 pm
    Or use C4D spline wrap 😉 I know, not AE, but some things aren’t always an AE job.
    Jason Jantzen
    vimeo.com/jasonj
  • Joseph W. bourke
    October 23, 2013 at 12:17 am
    You might give the Puppet Tool a try. It will allow you to warp your arrows, but you would have to do all the keyframing of points by hand.
    Joe Bourke
    Bourke Media
