Activity Forums Adobe After Effects Arrow moving away from you
  • Arrow moving away from you
    Posted by Bobby Dorrance on June 24, 2011 at 7:21 pm
    Hello, Im working on a spot for a snowblower right now. I need to make a 3d arrow that comes directly from behind camera and goes into the snowblower and then bends upwards to go through the hole. I have particular and I dont have a problem making a solid particle that follows the path I want. Where Im running in to problems is the arrow head. I cant figure out how to make a 3d arrow head that will move the way that particle does and stay attached to it. Any ideas?
    Thank you,
    Bobby D
    Bill Williams replied 15 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bobby Dorrance
    June 24, 2011 at 7:29 pm
    Ill give it a try. Never used that plugin. Thank you.
  • Michael Szalapski
    June 24, 2011 at 7:45 pm
    If that fails, you could go with Zaxwerks plugins. Serpentine might get the path you want and 3d Invigerator can get you the arrow you want.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Tudor “ted” jelescu
    June 25, 2011 at 7:30 am
    I think Michel’s suggestion will work best- Sepentine will give you the arrow head as well.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Bill Williams
    June 26, 2011 at 5:26 pm
    If it’s not too late, I made an arrow using Particular. It’s not the prettiest thing, but could save you from having to buy a plugin.
    Here is the project file…
    2484_arrowfolder.zip
    and here is a preview…
    Particular Arrow
    vurb.tv
  • Bobby Dorrance
    June 26, 2011 at 6:51 pm
    Thank you Bill and thank you to all other suggestions. This is very close to what I was looking for. I’ll take a look at the project file later on tonight.
    Thank you very much!
    Bobby D
  • Bobby Dorrance
    June 27, 2011 at 1:22 pm
    Bill, what you provided is awesome. After looking through your project file and examining the way you approached this, I am still a little confused on how you made the actual arrowhead. I am new to particular and maybe its something obvious that I am over looking but I can’t seem to find out how to make the front of the arrow. Hope you can guide me just a little bit more.
    Thank you,
    Bobby D
  • Bill Williams
    June 27, 2011 at 2:26 pm
    To make the arrowhead, I changed the particle size. To adjust the head, look at the keyframes for the size of the particle.
    vurb.tv
