Activity › Forums › RE:Vision Effects › arrow keys to nudge points?
  • arrow keys to nudge points?
    Posted by Matthew Beall on May 27, 2007 at 2:14 pm
    I’m using the Flex Warp operator in combustion.
    Can you not move/animate the points using the arrow keys? I’m doing some extremely fine warping. The mouse’s movements are too extreme.
    Plus, I find arrows easier to quickly set keys to all points by selecting them all and doing a quick up/down arrow.
    -Matthew
    Pierre Jasmin replied 19 years, 4 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    May 28, 2007 at 1:45 am
    Please file a bug to Autodesk
    Bug being as you describe that selecting a mask point in RE:Flex and pressing the up and down arrow does not move the point. This works in other Combustion tools like Draw Mask and would be expected to work in RE:Flex as well (same polygon toolkit).
    * Moving the tracker position within RE:FLex works but that’s of no help.
    * If you select the point in the timeline, there is a way (pressing shift) to increase the increments but apparently no way to decrease it so it so it moves by sub pixel increments.
    The only I can think to work around this today is by working on a zoomed up image (pressing the “+” zoom-in button a couple of time)
    Pierre
    http://www.revisionfx.com
