Activity › Forums › Apple Final Cut Pro Legacy › arriflex D21 workflow
  • arriflex D21 workflow
    Posted by Jeremy Pitard on January 24, 2009 at 11:12 am
    Hi Mr Creativecow
    It’s my first post in this website.
    And i’m a french, so i’m sorry if i make some grammaticals mistakes.
    I will edit a movie shoted with the arriflex D21 soon.
    So i have some questions about the computer requirements, the workflow and the storage.
    1-what’s the name of the arriflex files ? Is it Arriraw ?
    2-What computer requirements i need ?
    I think worked on Mac Pro Two 2.8GHz Quad-Core Intel Xeon with 4Go RAM. Is it a good choice ?
    And i don’t know which graphic card i need.
    3-For capturing “arriraw data”, have i need an Aja Kona 3 card ? or an other ?
    4- What’s the “weight” of the arriflex files.
    I hope somebody can answer me.
    Thanks a lot
    cordially
    Pit’
    Jeremy Pitard replied 17 years, 8 months ago 3 Members · 4 Replies
  • Gary Adcock
    January 24, 2009 at 2:40 pm
    [jeremy Pitard] “1-what’s the name of the arriflex files ? Is it Arriraw ? “
    The ARRIRaw capture from the D21 is fairly rare still- mostly you will get HDCAMSR tapes- there currently not a decoder for ARRIRaw for the FCP
    “2-What computer requirements i need ?
    And i don’t know which graphic card i need.”
    Without knowing what you are doing it is hard to determine- if you are working with D-21 RAW files that computer will BARELY handle the content. ( Been there, done that) Graphics cards only accelerate Motion etc. and do not effect playback.
    “For capturing “arriraw data”, have i need an Aja Kona 3 card ? or an other ?”
    the arri data files have to be captured on set using a Codex or Stwo solution to get to the RAW files.
    You will need a Kona 3 card- the BMD cards will not cut it with a frame at almost a 3K rez in ARRIRaw.
    “4- What’s the “weight” of the arriflex files. “
    LARGE You will need storage able to handle more than 2K DPX size storage- or over 300MBps a second
    This is not RED or DVCPROHD – these files are HUGE…
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Jeremy Pitard
    January 25, 2009 at 11:37 am
    Hi Gary
    First… thanks to answer me so fast. i appreciate it. Your explainations lighted my mind.
    I will ask more informations to my director. And i come back to you soon.
    Thanks a lot
    Jeremy
    Ps1… i hope my english is not too awful
    cordially
    Pit’
  • Misha Aranyshev
    January 25, 2009 at 3:13 pm
    First thing to ask your production is what are they recording to. The more likely options are HDCAM-SR, as mentioned, and s.two DDR. In both cases you will need a matching player. The player for s.two d-mags is s.two iDock. It has HD-SDI output and RS-422 control. It does decent real time debayering so you don’t bother yourself with RAW. iDock also has an Ethernet connection so you can copy data an FCP compatible XML from the d-mag to your edit station. In RAW and 4:4:4 RGB modes it is 8 MB per frame so get plenty of storage.
  • Jeremy Pitard
    January 26, 2009 at 8:33 am
    Hi everybody
    Thanks to you michael… Your advices are invaluable.
    Thanks a lot
    Jeremy
    cordially
    Pit’
