Activity › Forums › Avid Media Composer › ARRI LUT Plugin for Avid Media Composer
  • ARRI LUT Plugin for Avid Media Composer
    Posted by Casey Swircz on August 31, 2011 at 5:16 pm
    Does anyone know if there is a Alexa ARRI LUT plugin for Avid Media Composer? I know there’s one for FCP where you can simply drop the effect on the clip and the clip gets color corrected. Is there anything out there for Avid that works the same way? Preferably something free 🙂 Or at low cost.
    Casey
    Michael Phillips replied 15 years ago 3 Members · 3 Replies
  • Michael Phillips
    August 31, 2011 at 5:32 pm
    There is no support for a LUT or color profile as a source side effect in Media Composer. Only native RED R3D editing allows for a “source settings” for color as the AMA plug-in goes through the SDK which does the work…
    If you need to apply a LogC to REC709 LUT to sources, it needs to be done outside the application. – check out:
    AlexiCC: https://www.lightillusion.com/alexicc.htm
    or Pomfort’s SilverStack: https://pomfort.com/
    Or a Resolve Lite (free) to make QUickTime wrapped DNxHD via the QT codec (not native MXF wrapped DNxHD – that has a license fee attached).
    Michael
    Michael Phillips
  • Job Ter burg
    August 31, 2011 at 8:06 pm
    Hi Michael, can you elaborate on Pomfort? Hadn’t come across that yet.
  • Michael Phillips
    August 31, 2011 at 9:13 pm
    There is a lot of good information on their site:
    https://pomfort.com/formats/alexa.html
    Silverstack is a logging and basic color correction solution for file based media. The latest version support LogC to REC709 and can export QT wrapped DNxHD, exports an ALE that can be merged for all metadata logging.
    Michael
    Michael Phillips
