Activity Forums DaVinci Resolve Arri LUT included
  • Arri LUT included
    Posted by Stig Olsen on November 16, 2011 at 1:13 pm
    I just noticed that the 3D-lut “arri alexa log-C to rec 709” now is included in the menu. When did this happen? On the latest update?
    Is this the same as the one that can be made by the arri generator on their website?
    Stig
    Ryan Wu replied 14 years ago 4 Members · 6 Replies
  • Neil Sadwelkar
    November 16, 2011 at 3:02 pm
    No, as far as I remember, this was around in 8.0 maybe earlier. The Arri LUT generator LUT described in Arri’s whitepaper needs to be downloaded and placed in an appropriate folder.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Stig Olsen
    November 16, 2011 at 3:20 pm
    Ok, Guess I just missed it.
    So basically that means it does the same job as the built in one.
    When I apply this LUT the hightlight really blow out. They goes far out of range. Is that the way its suppose to act?
  • Neil Sadwelkar
    November 16, 2011 at 3:30 pm
    I’ve used the one recommended by Arri, made by their generator…
    Its called…
    AlexaV3_K1S1_LogC2Video_Rec709_EE_davinci3d.cube
    and that seems fine.
    It needs to go in
    /Library/Application Support/Blackmagic Design/DaVinci Resolve/LUT/Arri
    where you find the existing one called…
    Arri Alexa LogC to Rec709.dat
    which is what you’re using.
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
  • Andrew Smith
    November 17, 2011 at 6:08 pm
    Hey Neil great info thanks!
    any chance you can provide a link to the LUT you generated for me to download quickly?
    cheers
    Andrew
  • Andrew Smith
    December 5, 2011 at 1:16 am
    can you show a screen grab of exactly what setting you have when choosing the setting for generating the LUT?
    I just did the 10 bit option but i am curious now because the files i am working with are ProRes444 and in Davincic it says they are 16 bit – this is for a broadcast spot and of course i am working in 10 bit for resolve so any info would be helpful!
    cheers
  • Ryan Wu
    August 25, 2012 at 10:27 pm
    Can’t seem to find the( AlexaV3_K1S1_LogC2Video_Rec709_EE_davinci3d.cube ) LUT within my options.
    I checked my lib/application suport/blackmagic/LUT
    found this one as a LogC to Rec709:
    Arri Alexa LogC to Rec709.dat_3dlut
    it loads fine in resolve lite.
    Could someone point me to how to get this K1S1 LUT you are talking about?
    Many thanks in advance.
    R
    THX
