Activity › Forums › DaVinci Resolve › Arri LUT from the Arri website not working ?
  • Arri LUT from the Arri website not working ?
    Posted by Gabriele Turchi on May 3, 2011 at 9:28 pm
    Did Anyone successfully created Lut For alexa from teh arri website and used in Davinci ??
    I tried many many different settings in the Lut generator (1D Lut , 3D , photmometric , extended range or scaled etc…)
    , than i copied all this Luts (exported for resolve off course) into the cinespace folder (library, appsupp, black, dav etc…), But when loaded the Luts on a Node i always get a completely WHITE image …
    any idea?
    thanks
    g
    Rohit Gupta replied 15 years, 4 months ago 3 Members · 3 Replies
  • Tim Farrell
    May 3, 2011 at 10:56 pm
    Hi Gabriele,
    Instead of using the Cinespace folder, create a new folder within the LUT folder and call it Arri or whatever and try putting the LUTs in here.
    This works for me.
    Tim
  • Gabriele Turchi
    May 3, 2011 at 11:36 pm
    thanks a lot tim
    it worked !
    g
  • Rohit Gupta
    May 4, 2011 at 4:53 am
    It is important to name the sub-folder “Arri”. Other names won’t work!
    Alternatively, if you can download in the .cube format, you can copy it to the Cinespace directory, and it should produce the exact same result.
