Activity › Forums › Apple Final Cut Pro Legacy › Arri Alexa proxies in final cut??
  • Arri Alexa proxies in final cut??
    Posted by Daniel Jimenez on May 4, 2012 at 8:36 pm
    hi, i need to do an offline editing with some Arri Alexa footage, the issue is that I need to create proxies to use it in mi home station, how should i create this proxies?? which program should i use?? is there any log and transfer for alexa footage?? please help
    Nick Meyers replied 14 years, 4 months ago 3 Members · 3 Replies
  • Shane Ross
    May 4, 2012 at 9:40 pm
    [Daniel Jimenez] “how should i create this proxies??”
    Import the full res footage. Then use the MEDIA MANAGER and the RECOMPRESS option.
    [Daniel Jimenez] “which program should i use??”
    FCP. Anything else and you are looking at a lot of work, and a lot of issues reconnecting the media.
    [Daniel Jimenez] ” is there any log and transfer for alexa footage??”
    ALEXA raw? Or is it being shot ProRes? If ProRes, then L&T isn’t needed, it’s already in the format needed. If Raw…then the camera should be making the proxies itself.
    https://www.arrimedia.com/alexa/workflow
    Shane
    Little Frog Post
  • Daniel Jimenez
    May 5, 2012 at 5:01 pm
    i do some test with some clips, the properties are Apple pro ress 444 24fps, and i did the proxies with this setting Apple pro Ress (proxy) 24p 48khz, and when i finished, a message appear that says that my files arent in the same framerate, which setting should i use instead?? thanks guys
  • Nick Meyers
    May 8, 2012 at 11:00 am
    the FCP preset, while labeled 24p, has a frame rate of 23.98.
    you need to duplicate the pre-set, change the frame rate to 24, and use that to export.
    cheers,
    nick
