Activity Forums Apple Final Cut Pro Legacy ARRI ALEXA Log C ProRes 4444 workflow for FCP
  • ARRI ALEXA Log C ProRes 4444 workflow for FCP
    Posted by Alfred Wells on January 19, 2011 at 9:38 pm
    Hi Everyone,
    I’ll be getting some ARRI ALEXA shot footage in the next couple days to chug into my final cut pro. These are coming to me as Log C ProRes 4444 files. I’m assuming I can just bring them into final cut and start editing.
    Wondering if it requires some transcoding and whether or not there’s a program or plugin out there.
    I have Nick Shaw’s plug in. Wondering if I need to buy software. Basically any kind of workflow suggestion will do. Clearly I’m a bit clueless with the ALEXA.
    Jeremy Garchow replied 15 years, 7 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 19, 2011 at 11:43 pm
    That’s the beauty. Import the files and start editing.
    You might need a temp grade in the footage to make it look pleasing, or use a lut with your capture card, but you can edit @ prores4x4 in fcp.
    Do you have an external monitor and capture card?
