Activity Forums VEGAS Pro Arrgh! Memory errors are killing my 10 hour render
  • Arrgh! Memory errors are killing my 10 hour render
    Posted by Jeffrey Ellis on October 6, 2009 at 4:27 am
    So I’ve now tried rendering this one file 3 times, all failing with memory errors. I’ve only got a gig and half about, but last week, the same file was rendering no problems.
    Anyone know what might be going on here?
    EDITED: Looks like it’s happening in the same place each time. I created a freeze frame by saving a frame as a jpeg and then bringing it in. I then added a fade. In the middle of the fade is where the error is ruining the render.
    EDITED MORE: It looks like just after the fade there’s just some blank space in the video before the next clip. I thought since it was a fade out, a few seconds, then a fade in, that this blank space would simply be rendered black.
    Is there a way to fill the space with just black?
    Linda O’connell replied 16 years, 10 months ago 2 Members · 1 Reply
  • Linda O’connell
    October 15, 2009 at 2:11 am
    Have you checked the size of the particular jpeg file where you are having problems?
    I had the same problem and discovered I was importing a jpeg file way too large for Sony to support.
    Don’t know if that will help or not?
