Activity › Forums › Adobe After Effects Expressions › array[value, value] to control rotation [layer#1, layer#2]
  • array[value, value] to control rotation [layer#1, layer#2]
    Posted by Jouni Kuuva on September 10, 2020 at 10:50 pm
    (I actually have 36 graphic objects, but for the sake of simplicity, let’s say that … )
    … I have 4 objects, each on their own layer.
    I want to rotate the them to make graphic patterns.
    How to make a script that tells layers #1, #2, #3, #4
    to rotate to array values [1], [2], [3], [4], respectively.
    So I would have f.ex. these arrays:
    flowerArray = [45, 135, 225, 315];
    boxArray = [0, 90, 0, 90];
    How to make this happen (?):
    At keyframe 50, rotation is defined by flowerArray:
    Layer#1 rotates to 45°
    Layer#2 rotates to 135°
    Layer#3 rotates to 225°
    Layer#4 rotates to 315°
    At keyframe 100, rotation is defined by boxArray:
    Layer#1 rotates to 0°
    Layer#2 rotates to 90°
    Layer#3 rotates to 0°
    Layer#4 rotates to 90°
    Dan Ebberts replied 6 years ago 2 Members · 1 Reply
  • Dan Ebberts
    September 11, 2020 at 4:07 pm
    I’m guessing this isn’t exactly what you’re talking about, but it might give you some ideas:
    startFrame = 50;
    endFrame = 100;
    t1 = framesToTime(startFrame);
    t2 = framesToTime(endFrame);
    linear(time,t1,t2,flowerArray[index-1],boxArray[index-1]);
