Activity › Forums › Adobe After Effects › Array piece can’t expand to more than one value Error, please heelp!
  • Array piece can’t expand to more than one value Error, please heelp!
    Posted by Alejandro Ubaldo Morales on October 25, 2023 at 1:17 pm
    I am trying to follow an AE tutorial to learn code from zero, at the exercise in minute 30, we need to make a circle (elipse path) color red if the X Position value is greater than 960, but the code i am copying from the video is not working giving me that error, i would appreciate any help for this beginner, here is my code:
    1. var red = [215,68,63,255] / 255;
    2. var black = [51,58,55,255] / 255;
    3. if(transform.xPosition > 960) [
    red
    else [black] I am using AE version 2023, and the tutorial is from 2021, i don’t know if that has anything to do with this issue.
    Here is the link to the tutorial: https://www.youtube.com/watch?v=Knp2S_gs-Rc
    Alejandro Ubaldo Morales replied 2 years, 10 months ago 2 Members · 2 Replies
  • Walter Soyka
    October 25, 2023 at 6:41 pm
    In Javascript, square brackets indicate arrays (lists) and curly braces indicate blocks of code (such as would follow an if/else statement. You are using square brackets where you should be using curly braces.
    Try this:
    if (transform.xPosition > 960) {
    red;
    } else {
    black;
  • Alejandro Ubaldo Morales
    October 25, 2023 at 11:12 pm
    In the Tutorial he uses […] instead of (…) and it works, i wonder why.
    Anyways you saved me, thank you so much!!!
