  • Posted by Chris Korangy on July 24, 2021 at 5:45 pm
    Hi all,
    I’m having a go writing my first script but I can’t seem to wrap my head around why this isn’t working. I have 12 items in my project folder and 12 items in this array. What I’d like is for the first item to duplicate by the first number of the array (duplicate 3 times), then the second item to duplicate by the number in the 2nd array etc.
    What am I missing? any help much appreciated!
    myArray = [3,2,5,3,6,9,7,6,5,7,5,6];
    for(i=1; i<=app.project.numItems; i++){
    var curComp = app.project.item(i);
    var curDup = myArray[i];
    for(d=1; d<=curDup; d++){
    curComp.duplicate()
    Chris Korangy replied 5 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 24, 2021 at 6:00 pm
    I think the main thing is that you’re trying to loop through the project items while you’re adding items. Without knowing how you have things set up, I’d guess you should probably first put all the comps you want to duplicate into an array and then loop through that.
  • Chris Korangy
    July 24, 2021 at 7:18 pm
    Ah yes I see, that makes sense now. I will give that a go, thanks Dan
