Activity › Forums › Apple Final Cut Pro Legacy › Argh! Exported ProRes .mov files wrong file size
  • Argh! Exported ProRes .mov files wrong file size
    Posted by Brad Bussé on March 5, 2012 at 6:52 pm
    I’m working on a client’s setup with FCP 6.0.6 running on OS 10.6.8. When I export a Quicktime Movie, it then shows up with the wrong file size in the Finder. The Finder says it’s 12 MB in size, but if I then open the file in Quicktime Player, it plays fine and a Get Info in QT Player shows the correct file size of 950 MB. I tried to compress in Handbrake, and it didn’t work. I also copied the files to a PC and there it also shows the wrong file size, so view the file like on the Mac. Anyone know what’s going on? I repaired permissions and ran cron jobs the other day and it didn’t fix this problem.
    Brad Bussé replied 14 years, 6 months ago 3 Members · 3 Replies
  • Chris Tompkins
    March 5, 2012 at 6:53 pm
    So,….What size do you need it to be?
    Drop in Compressor and create a .h264 mov file, dial in the data rate as needed.
    Chris Tompkins
    Video Atlanta LLC
  • Neil Patience
    March 5, 2012 at 6:55 pm
    It sounds like you may have created a QT reference movie rather than a self contained one.
    When you export make sure the self contained option is set.
    Should then see a movie file of the correct size.
    best wishes
    Neil
    http://www.patience.tv
  • Brad Bussé
    March 5, 2012 at 8:51 pm
    Thank you, I think you solved it. It exported okay after trashing prefs, so I guess the old prefs I was using defaulted to not export self-contained.
