Activity Forums Apple Final Cut Pro Legacy Argggghhhh -No chapter markers in H264-compressed QT???
  • Argggghhhh -No chapter markers in H264-compressed QT???
    Posted by Tom Donnelly on October 1, 2008 at 4:58 pm
    Hi all:
    I am exporting a self-contained movie using setting “Show DVD Studio Pro Markers” – the sequence and of course the exported file are ProRes codec.
    When I open the QT outside of FCP, all the chapter markers are there in Quicktime viewer window (lower right, popup that allows me to jump to points in the movie)
    Next I import to Compressor – All the markers (edit point markers as well as chapter markers that I have set…) DO show up in the Compressor preview window. All looks good…
    I encode an h264 QT from compressor – but in the encoded QT, there are NO chapter markers present!
    I attempted a workaround of extracting the text track from the original exported QT and “Adding to movie” of the h264 QT using quicktime. Then I turn off the text track but keep on the popup that says Chapters > Text Track under “Other Settings” in the properties window of the h264 QT. The chapters are then visible in the lower right of the viewer window. BUT – when I close the movie and “save” then re-open, they are gone…argh!
    It has to be user-error, but I feel like I’ve covered all bases and searched this forum for similar problems, but still in the dark.
    Help!
    Tom Donnelly replied 17 years, 11 months ago 3 Members · 4 Replies
  • Eric Pautsch
    October 1, 2008 at 5:24 pm
    Whats the final purpose of this encode? DVD?
  • Tom Donnelly
    October 1, 2008 at 5:29 pm
    No – final output is just what I am trying to spit out from Compressor – just a quicktime movie, h264, with chapter markers.
  • Chris Poisson
    October 1, 2008 at 6:58 pm
    Tom,
    To do what you want, you can skip Compressor. From your timeline, select Export>QuickTime, NOT QT conversion, select the chapter marker setting, then go into current settings and select “custom,” then change the compressor to H.264 and set a data rate, voila, a beautiful movie with markers.
    Have a wonderful day.
  • Tom Donnelly
    October 1, 2008 at 7:04 pm
    True, I tested that – but I have many movies daily that need this treatment, pus other formats to export to. Batch processing with Compressor really my only option.
    That being said, I knew it had to be user error – if I hit “m” twice and bring up the marker dialog box and manually set each one to “chapter marker” it works. Duh. I had just been setting plain ol’ markers in FCP.
    Thanks for the help, all…
