Activity Forums Maxon Cinema 4D Area Lighting problems
  • Area Lighting problems
    Posted by Rusherific on August 2, 2006 at 12:30 am
    I’ve been in Lightwave for a long time, and have had to get Cinema under my belt for my current gig. One thing that’s getting me is that it seems the closer to an area light an object, the LESS bright it is. Say if I have an area light just outside a window to simulate sun inside a room, the window pillars are almost black while the far wall is lit nicely. I’ve messed with pretty much every setting–Is this just an artifact of area lights, or am I missing something?
    Thanks in advance!
    Rusherific replied 20 years, 1 month ago 3 Members · 3 Replies
  • Björn Marl
    August 2, 2006 at 6:32 am
    Have you tried switching on inverse square falloff?
    Cheers
    Bj
  • Amish Ed
    August 2, 2006 at 5:13 pm
    Might want to try dropping down your shadow’s strength.
    Amish Ed
    “Shoot ’em all and let the Editor sort ’em out!”
    Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
  • Rusherific
    August 2, 2006 at 6:27 pm
    Yeah it helps a lot to set a falloff, but seems like it shouldn’t have one if its simulating sunlight, but it gets the job done for a room 🙂
