Activity Forums Maxon Cinema 4D Are these effects being created in c4d or trapcode form or both?
  • Are these effects being created in c4d or trapcode form or both?
    Posted by Joey Campbell on August 12, 2013 at 5:52 pm
    Hi I’ve a few questions about techniques used in this clip:
    https://vimeo.com/51265319
    If anyone could give me some advice it would be great.
    At 23s-25s is there ‘one’ power transformers being duplicated by trapcode particular or have the models been duplicated in c4d beforehand ?
    At 40-53s is trapcode form being used to split the meshes apart into vertical sections or can this be done inside c4d ?
    I was wondering what render settings are being used to get the effect that is on the satellite and satellite dish at 1m41s….is it trapcode form or can c4d be set to export like that ?
    Finally a similar question but is the globe at the intro to this clip an obj brought into trapcode form with the camera animated inside afx or is it an image sequence exported from c4d into afx with an exported camera also from c4d >?
    https://vimeo.com/63502573
    Joey
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Joey Campbell replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
