Forums Avid Media Composer Are these avid quicktime codecs safe to download/use?
  • Are these avid quicktime codecs safe to download/use?
  • enrique bartolo
    April 19, 2016 at 3:32 am
    I’m a windows user and I had to uninstall Quicktime because Apple is refusing to support it etc etc. So I found these avid quicktime codecs and I was wondering if I can just download and use the codecs for exporting videos in Davinci Resolve 12 lite.
    https://avid.force.com/pkb/articles/en_US/download/Avid-QuickTime-Codecs-LE
    If anyone can let me know if it’s okay to download them, then that’ll be swell!
  • Eric Santiago
    April 19, 2016 at 3:59 am
    They are the same.
  • Shane Ross
    April 19, 2016 at 4:24 am
    You can download them, but they won’t work unless you have Quicktime installed. They aren’t separate. Quicktime is a container, as well as an application. The codecs only work inside that container…and they will only work if you have QT installed.
    Shane
    Little Frog Post
  • enrique bartolo
    April 19, 2016 at 8:06 am
    Isn’t there like a work around to install QuickTime for just its codecs?
Viewing 1 - 4 of 4 posts
Log in to reply.
