Activity › Forums › Maxon Cinema 4D › Are there anyway to pre-set object properties in primitive object?
  • Are there anyway to pre-set object properties in primitive object?
    Posted by Npoomviset on December 3, 2006 at 6:46 pm
    Are there anyway to preset object properties in primitive object?
    Everytime I use “Add cube object” in Primitive, the cube alway come at (200cm,200cm,200cm).
    I really want to set it as (10cm,10cm,10cm.)
    Thank you very much in advance
    Mylenium replied 19 years, 10 months ago 2 Members · 1 Reply
  • Mylenium
    December 4, 2006 at 4:11 am
    Change your settings to what you want them to be, then in the attribute manager select Edit –> Set as Default.
    Mylenium
    [Pour Myl
