Activity Forums Panasonic Cameras Are there any HPX Scene Files for Green Screen?
  • Are there any HPX Scene Files for Green Screen?
    Posted by Matt Mcalonie on February 21, 2012 at 4:02 pm
    Might anyone know of any scene files specifically for Green Screen shoots?
    I have had poor results (noise) with both an HPX 300 and 370 with a well lit Matthews 20×20 chroma screen. Shooting in 1080p 24 Avc Intra 100. The shots look terrific on site via an sdi out to monitor, but when we get them into AE there’s a bit of noise everywhere and even more on the green screen. I have had very good results with these cameras over the past two years with a select few scene files but haven’t shot green screen but twice. I must have the camera setup way wrong and/or should be using a digital green instead of chroma green?
    Thanks for any suggestions!
    Understanding that I need to bring down the detail level, what else needs to be done?:
    SCENE NAME :DIG30
    00005000: 1 ; VFR : OFF
    00005001: 30 ; FRAME RATE: 30 FRAME
    00005002: 01AB0708 ; (SYNCHRO SCAN):
    00005003: 12 ; DETAIL LEVEL: 4
    00005004: 8 ; V DETAIL LEVEL: 0
    00005005: 13 ; DETAIL CORING : 5
    00005006: 7 ; CHROMA LEVEL: -1
    00005007: 10 ; CHROMA PHASE: 2
    00005008: 9 ; COLOR TEMP Ach: 1
    00005009: 8 ; COLOR TEMP Bch: 0
    0000500A: 113 ; MASTER PED: -15
    0000500B: 16 ; A.IRIS LEVEL: 0
    0000500C: 2 ; DRS EFFECT: 3
    0000500D: 1 ; GAMMA : LOW
    0000500E: 2 ; KNEE: LOW
    0000500F: 2 ; MATRIX: FLUO
    00005010: 1 ; SKIN TONE DTL : OFF
    00005011: 0 ; V DETAIL FREQ : THIN
    Adrian Jans replied 14 years, 6 months ago 4 Members · 3 Replies
  • Fernando Mol
    February 21, 2012 at 6:22 pm
    I think the MATRIX:FLUO is for fluorescent light and it cut the greens. Not what you want.
  • Steve Eisen
    February 22, 2012 at 4:26 am
    A few things catch my eye:
    1. Detail level – Bring Down
    2. Detail Coring – Bring Down
    3. Master Pedestal – I can’t see what you are shooting but you may be crushing your blacks which can add noise to your picture.
    4. Turn DRS OFF. This is where a lot of noise is coming from.
    Matrix: Fluo is no good for green screen.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Adrian Jans
    March 1, 2012 at 10:37 pm
    I use an HPX170 so this might not translate perfectly to your camera, but personally I like MATRIX: Cine-Like, it over-saturates things a bit, but that does help separate your greens.
    I also usually use GAMMA: LOW, but depending on what you’re recording and how even your lighting is, B. Press is also pretty good and often the least noisy.
