Activity › Forums › Boris FX Particle Illusion › Are there any good mushroom cloud explosions out there?
  • Rinny8
    November 22, 2005 at 12:32 am
    oh…and one more thing. Is there anyway to make particles climb up walls and stuff? Say like having cracks run up a wall or a wall rotting away or something. I saw something like this on the Wondertouch website but I think it was proffesional…
  • Elvis Deane
    November 22, 2005 at 7:47 pm
    There are a bunch of mushroom clouds in the July 2004 library.
    The best example I’ve seen of rotting/cracking type effect is the clip from Smallville on the pI demo reel (the hand placing the dis)
    I think that was done by using an emitter as a displacement or bump map in a 3D program. Super emitters with high f-Velocity, long particle Life, and low particle velocity should be able to create a nice growing crack effect that you can then map onto 3D geometry
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • Alan Lorence
    November 22, 2005 at 7:55 pm
    [Elvis Deane] “I think that was done by using an emitter as a displacement or bump map in a 3D program”
    I believe the “don’t erase” option was used as well, so the particles “draw” the cracks.
    Alan.
    wondertouch
  • Rinny8
    November 22, 2005 at 9:06 pm
    unfortunatley I ‘m not a 3D person…
  • Rinny8
    November 22, 2005 at 9:07 pm
    oh well thanks for the library!
  • Elvis Deane
    November 22, 2005 at 9:32 pm
    A lot of compositing and editing programs have bump/displacement filters that can get similar effects to a 3D displacement map. Have a look at whatever software you use.
    Elvis Deane!
  • Rinny8
    November 22, 2005 at 9:42 pm
    ok thanks!
