Activity › Forums › Adobe After Effects › Are there any 3rd party plugs for motion tracking?
Posted by Mike Schmitt on October 26, 2006 at 1:04 pmHi there:
Struggling along with the AE motion tracker. As great as it is, I’m wondering if there are any third party plugs that do the same thing or have more features.
Can you suggest any?
Paul Miller replied 19 years, 11 months ago 5 Members · 5 Replies -
Tony Kloiber
October 26, 2006 at 2:57 pmThis is a roto plug in but also has a tracker
https://www.silhouettefx.com/index2.htmThis is a standalone app but export data to AE
https://www.thepixelfarm.co.uk/contentfull.aspx?Content=pfhoe_more.htmSame here
https://www.ssontech.com/TonyTony
Jimmy Brunger
October 26, 2006 at 3:35 pmBrilliant stuff – so should that Silouette plugin enable you to roto and track in AE7.0 as well as you can in Combustion?
That’d be brilliant if so, I HATE the combustion UI and workflow!! Silouette roto looks to have proper B-splines and variable edge blurs..in AE…GOOD STUFF!
Anyone use this plugin at all? For
Tony Kloiber
October 26, 2006 at 4:03 pmWell, I believe you can download it and run it in demo mode so that you can find out for yourself.
If you can bear the excitement :0
TonyTony
Paul Miller
October 26, 2006 at 5:09 pmYes, you can track and roto (and paint!) inside AE using an interface designed specifically for such things. You can export your roto shapes and trackers back into AE to use natively.
