Activity Forums Avid Media Composer Are slashes “/” in archival date column OK?
  • Are slashes “/” in archival date column OK?
    Posted by Timothy Ballard on June 28, 2017 at 12:19 pm
    Hello,
    Simple question: I’m entering data for archival material in Avid and I don’t seem to have any issues so far, but just double-checking that as I enter dates for archival clips in a custom column with this format – year/month/day (ex: 1945/02/21 ) – that there will be no issues later on with the slashes.
    I usually avoid anything other than _ for punctuation in Avid, but I think in this case it is easier to enter and read with the slashes.
    In addition, some of the data contains ” #’s” in another column for original file name. Will these be an issue?
    Mike Harper replied 9 years, 2 months ago 4 Members · 3 Replies
  • Eric Santiago
    June 28, 2017 at 1:00 pm
    I would avoid using that character or any odd characters.
  • Michael Phillips
    June 28, 2017 at 1:04 pm
    You should be “OK” as long as it is metadata that is transmitted via ALE, AAF, etc, and is not a field that would be used as a filename at the OS level anywhere in the process like export, etc.
    Michael
  • Mike Harper
    June 29, 2017 at 2:21 am
    I would avoid you may have issues with other apps down the road. The_ should be be safe.
    Mike Harper
    https://www.editscore.com/
    https://editscore.sourceaudio.com
