Activity Forums Adobe After Effects Are scale changes intelligently combined when AE renders?
  • Are scale changes intelligently combined when AE renders?
    Posted by Mike Cantor on June 4, 2012 at 5:38 pm
    Will there be a difference in the final render between the following three cases, all of which have the total impact of scaling a piece of footage by 225%.
    Case 1: A piece of footage is set to scale = 225%
    Case 2: A piece of footage is set to scale = 150% and parented by a layer that scales at 150%
    Case 3: Comp A contains a piece of footage scaled at 150%. Comp A is nested within Comp B, wherein it is scaled at 150%.
    Thanks for any info you can offer on this.
    -Mike
    Mike Cantor replied 14 years, 2 months ago 2 Members · 4 Replies
  • Mike Cantor
    June 4, 2012 at 6:43 pm
    Thanks Dave!
    My question was more about the render result, not the time of rendering. Here is my I actual issue
    I have a comp (call it “CompA”) at 720 that contains footage that is scaled down to about 25%, which has a million tiny adjustments in the form of position changes, paint corrections, etc.
    I want to recreate this comp at 1080. Of course the easiest thing to do would be to drop CompA into another comp and scale it up. But will I lose resolution this way? If the rendering engine sees footage that is scaled to 25% in one comp and then rescaled by %150 when that comp is nested in another comp, is it smart enough to do one scaling operation, or will do the 25% scale first (losing all that resolution) and then do the second scale?
    Thats really the question I am asking for each of those three scenarios.
    -mike
  • Mike Cantor
    June 4, 2012 at 8:11 pm
    Thanks again, Dave. What would you suggest as search terms to look it up by?
    -mc
  • Roland R. kahlenberg
    June 5, 2012 at 12:39 am
    [mike cantor] “I want to recreate this comp at 1080. Of course the easiest thing to do would be to drop CompA into another comp and scale it up. But will I lose resolution this way?”
    Collapse Transformations is the AE feature you will want to look into – it should help under the conditions you’ve mentioned, ie concatenate transformations across more than one comp into a single execution. There are write-ups and tutorials at the COW on the subject.
    As for the script that Dave alluded to, it’s called ScaleComposition.jsx. You can access if via File>Scripts>ScaleComposition.jsx. Then set the appropriate value for the new comp. It’s useful/important that you make a backup of the 720 comp so that you have access to the original.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Mike Cantor
    June 5, 2012 at 2:15 am
    Thanks so much! I’ll take a look at both of those options. FYI I found a script that scale recursively. Don’t know how well it works.
    https://aescripts.com/recursive-scale-comp/
