Activity › Forums › Adobe After Effects › Are masked colour solids vecto or bitmap.
Posted by Steve Dann on May 6, 2010 at 8:06 amI’m using a mask to cut out a map coastline on a colour solid but when I scale it up it loses quality as though its a bitmap. I thought AE was vector (apart obviously from imported video and photos etc. Thanks.
Steve Roberts replied 16 years, 4 months ago 3 Members · 5 Replies -
Gary Hazen
May 6, 2010 at 5:20 pmI’m going to disagree with Dave here and say that solids are vector based*. You simply need to hit the continuosly rasterize switch – You should be good to go. The only caveat is that it affects the render order. That’s a whole different thread.
*Note – I think the AE versions prior to CS3 the solids were bitmapped. Hopefully Todd will chime in and clarify this point. I could be wrong about this, it wouldn’t be the first time.
Steve Dann
May 6, 2010 at 6:46 pmThank you both for the time and trouble to answer my query. More complicated than I thoufght, as usual. I wil do the necessary research now I know where to look, forgot all about ‘rasterize’ !
Gary Hazen
May 6, 2010 at 6:59 pmSolid layer scaled to 800% on CS4 looks clean here.
I have AE 6 at the house on a G5 I’ll check that later tonight, unless of course Todd chimes in before then.
Steve Dann
May 6, 2010 at 8:10 pmThank you all. I’m embarrassed to admit my problem was thatthe rasterise button wasn’t on. Simple as that. DOH !!!! Everything looking good now.
Steve Roberts
May 7, 2010 at 1:00 amThey changed the nature of solids at one point, Dave. It was a big deal, if I recall.
Well, to us AE geeks, anyway.
