Activity Forums Storage & Archiving Are external hard drives safe from static electricity?
  • Are external hard drives safe from static electricity?
    Posted by Juan Juig on February 22, 2020 at 10:16 pm
    I have around 10 external hard drives, some 2.5 inch and some 3.5 inch. They are all protected with plastic enclosure (I bought them like that).
    When I transport and store them, I use hdd cases like this one (I own several of this one specifically):
    https://uk.hama.com/078361/hama-universal-case-for-external-hard-drives-size-s-black
    Since the inside of the cases is made out of some sort of fabric material, I assume when you put the hdd inside it and rub it a bit, some static electricity is present.
    I have never had any problems whatsoever, but I am wondering, whether transporting and storing your external hdd in these type of cases is completely safe?
    And the main question: does the plastic enclosure that the hdd comes in completely protect the hdd from this sort of static electricity (generated by a bit of rubbing to the fabric material) or should I be worried and take some extra precautions?
    Juan Juig replied 6 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
