Activity Forums Adobe Premiere Pro Are bracket key audio adjustments adjustable?
  • Are bracket key audio adjustments adjustable?
    Posted by Ron Craig on May 13, 2016 at 10:40 pm
    What I mean by that subject line is: I use the bracket keys (without the shift key) to adjust a clip’s audio level. But the amount that those keystrokes increase or decrease the clip’s audio is more than I would like. I’d like to be able to make smaller adjustments with each keystroke. Is there a way to adjust that? Thanks.
    Ron Craig replied 10 years, 4 months ago 1 Member · 1 Reply
  • Ron Craig
    May 13, 2016 at 10:43 pm
    Well, I found the answer quickly. There are choices for “Nudge audio volume +1 or -1 db” in the keyboard shortcuts. Hadn’t found that before. I’m going to assign those commands to the bracket keys.
