Activity › Forums › Storage & Archiving › Archiving with BRU PE
  • Archiving with BRU PE
    Posted by Matt Dunne on September 16, 2015 at 4:46 pm
    Hey everyone. I’ve been using BRU PE for a little over a month now and am pretty happy with it. I’m working on revamping our archiving process and want to pick the brains of the community.
    Right now when we shoot we put the footage on the server and then back the project up on a master external drive and a backup external drive. When the project is finalized we compare the server copy with the two external drives and take it off the server.
    We’ve recently introduced LTO into our workflow so right now I’ve been taking all the master drives which are ready for archiving and putting them onto LTO. Now I’m running into a spot where the master drives and backup drives have projects that are finalizing at different times.
    Does it make sense to keep doing append backups on those tapes? Say drive A had 4 projects that were finalized and 1 that wasn’t and drive A was put onto LTO. Should I be concerned about constantly having to do incremental LTO backups for when the last project finalizes?
    Appreciate your input.
    Matt Dunne replied 11 years ago 2 Members · 2 Replies
  • Tim Jones
    September 16, 2015 at 5:45 pm
    You should actually look at this as two different processes using 2 different sets of tapes (tapesets).
    1> Archive completed projects. These projects are placed / appended onto tapesets that will be stored for long term retention and recovery.
    2> Backup working projects. These projects are dynamic and this is where performing a full followed by incremental jobs is your safety net.
    Once a working project is completed and delivered, see step 1 :). You may then rotate the working project’s tapes back in for the next set of working project backups.
    BTW – that applies to any process, not just BRU PE :).
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.tolisgroup.com
    BRU … because it’s the RESTORE that matters!
  • Matt Dunne
    September 16, 2015 at 9:30 pm
    Thanks for responding Tim. Just so I know I haven’t been saving the jobs through the operation window. Is that something I should be in the habit of doing? Is there a difference between doing an incremental backup this way and “appending” the tape? Is there a way to retroactively save the jobs I’ve done in the past?
