Activity › Forums › Storage & Archiving › Archiving video from PC to VHS using Firewire.
Sebastian Fudali replied 4 years, 6 months ago 4 Members · 16 Replies
Sebastian Fudali
March 15, 2022 at 8:56 pmAt this moment, I render the master DV file and output it via FireWire from PC, through D8 camcorder’s analog outs to my D-VHS. The caveat is I have PAL machine and PAL DV is 4:2:0, which is enough colour quality, Not the Smartest Choice is 4:1:1 and this is less tham optimal, hence many people denouncing that method, I have spoke about it with a known professional and he says there’s nothing wrong with PAL DV route. Also, your NTSC D-VHS machien has both FW in and out and the output will be in MPEG-2, so you can use it directly for ripping. My PAL deck, one of 3 PAL models ever made only supports DV input, like all 3 models. No digital output on them. So here’s where my trusty D8 camcorder comes in as A/D converter.
Also, I know this duplicator, I’m saving cash for one, but it doesn’t have SDI input, it has propriatary Y/C connector for analog video input. Unless you know a specific model with SDI.
as for that BD/VHS combo model, there are demos on youtube, the image quality is below archiving quality, it’s passable to watch, but I wouldn’t transfer it. Plus, composite and S-video are perfectly capable of transmitting resolution far greater than that of (S-)VHS, so there’s nothing wrong there. Unless that LaserDisc RF ripping method was finally successfully adapted for VHS. -
Jack Jack
March 15, 2022 at 9:13 pmAh, good to know. Thanks for letting me know about the Y/C signal for the VHS duplicator. I literally started my research yesterday, lmao.
As for the composite or S-video, I am not happy with the quality. I see much better results from other people’s methods vs my previous experience with composite and s-video. If I record (for example) a terminator 2 clip from my pc via composite and compare it to my terminator 2 original VHS, the quality of the original VHS is much sharper. I feel composite video really blurs the source too much.
I was not aware of the BD/VHS unit’s issue. I was convinced by many it was a very decent system. Had it for about 5 years now. I haven’t seen any demos since I got it. Something I’m going to look into now i guess, lol. Do you have any links I can follow? -
Jack Jack
March 15, 2022 at 9:37 pmI’ve been going through some comparison videos, and they really don’t do the Panasonic BD-VHS player justice. The player outputs at 444 12-bit, which might look more washed out if comparing it to composite or S-video on a TV that doesn’t have color set up for the former purpose. The colors might seem washed out, but it is more color-space to play with. There is more room to adjust darks and whites, and there is also ultra-black to consider from HDMI being turned on or off. Ever since they updated the firmware on the machines, I’ve had excellent results.
Sebastian Fudali
March 16, 2022 at 7:39 amIn terms of post editing and colour correction probably yes, but it won’t do S-Video tapes.
What is your setup for recording from computer?
Keep in mind that for duplication they were using either 1″, C-type, or later digital formats like D-1 to D-3, only at the dusk of VHS era they used DVCAM and the like.The results my workflow produces are crystal clear. It might be, that your combo unit is simply not that good in recording.
Jack Jack
March 16, 2022 at 8:08 pmThe BD-VHS unit doesn’t record onto tapes, it has no record function, it’s strictly to output VHS via HDMi. I’ve tested it using a few capture cards, and even upscaled to 4k using the HDfury DIVA, but its HDMi 2.1’s 4k 444 depth limit is 8-bit, so I’d much rather record in 1080p 12-bit and upscale in post. Great quality to be honest. Capture cards used are Blackmagic 4K quad, the Micomsoft X-Capture1 and the ElGato 4k60 mk2 with updated firmware for 444 12-bit depth.
As for Outputting from the PC to Standard definition, i have a few methods. Most of them involve composite or s-video output. I have basics, mini-displayport to composite/s-video, HDMi to composite/s-vide, VGA to composite/s-video, DVI to SDI then my favorite Canopus VGA to FireWire, a HDMi to FireWire (bit strange that one), then some thunderbolt/pcmcia/usb3 blackmagic, matrox and micomsoft capture cards with breakout cables and output ports for Y/C, composite, s-video, SDI … a 4k atem, a 4k Ultrastudio … I have a some gear that can output really good quality to be honest.
What I am missing is a VCR that can input/record anything other than composite/s-video. The average VCR isn’t good enough. If those DVHS VCRs you asked about can record the FW DV onto VHS or SVHS, and work really well, keeping the quality during the digital to analogue conversion, I’d like to look into them.
I am still very much interested in VHS dupilcators or a stack of pro VHS editing units as the solution for my VHS projects. The additional hookups and editing tools would probably help with yielding better results anyhow. I found a few cheap ones for under $100. Any you might recommend?
Sebastian Fudali
March 16, 2022 at 8:16 pmSounds like a lot of gear. I had limietd budget and options, so I adapted the bare minimum I already had.
There could be some professional studio editing VCRs that can accept composite, but I’m afraid nothing better than that.
That being said, this is more or less (sans youtube compression) how my D-VHS machine records and plays back VHS from digital source:
https://www.youtube.com/watch?v=-SL3sCacIc4
By mistake the raw DV transfer file ended up on youtube which downized it to 480 from source 576, I had the youtube master prepared upscaled to 1080, but it ended up not used.Also I am interested in whatever models you were able to find around ~100$.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
