Activity › Forums › VEGAS Pro › Archiving using copy and trim media
  • Archiving using copy and trim media
    Posted by Larry Watts on December 5, 2006 at 6:57 pm
    We need to find a quick way to archive a project including media so that we can later go back and re-edit a project to update it.
    I’ve tried the saves as with copy and trim media box marked and it helps a lot.
    What I need is to find a way so that all media copied goes into a new folder. The AVI’s get a new date but the jpg’s don’t which makes it harder to gatehr them into a new folder.
    Any successes out there?
    Larry
    LSW
    Jerry Waters replied 19 years, 9 months ago 3 Members · 2 Replies
  • Dv Memories video
    December 5, 2006 at 8:11 pm
    I do this quite often, and save the entire project onto a new hard disk and new folder.
    Whatever folder you specify when you “save as”, it will put all the files there.
    DV Memories Video, Inc.
    Your Local Videographer
    http://www.dvmemories.us
    Business Promotional Video, Weddings, Events, Editing, Transfers, Duplication and more!
  • Jerry Waters
    December 6, 2006 at 10:44 pm
    But a note of caution: if you save more than one veg to that folder it will just dump all the data together — which sometimes is OK if you have a big project in several vegs.
