Activity Forums Compression Techniques Archiving spots with Cleaner or Episode
  • Archiving spots with Cleaner or Episode
    Posted by Bryon Middleton on November 9, 2007 at 2:50 pm
    Does anyone have any insight into proper settings to use for archiving media 100 edited spots as quicktimes using Cleaner or Episode? I back up all my projects and media externally, but sometimes it would be nice to have high quality quicktime movies saved on my hard drive that i could just pull up quickly to show clients or something.
    Daniel Low replied 18 years, 9 months ago 3 Members · 2 Replies
  • Jeff Greenberg
    November 13, 2007 at 7:56 pm
    Well, if you have the Media 100 codec installed, you could compress the files as h.265 (in either cleaner or compressor) and get fantastic looking fairly small files.
    But I wouldn’t edit with them.
    I’ve seen one or two workflows using alternate QT codecs that use lossless compression to shrink the file (and therefore still useful for editing)
    Best,
    Jeff G
    Principal Instructor
    Future Media Concepts
    FMCTraining.com
    Editorsretreat.com
  • Daniel Low
    November 16, 2007 at 10:44 am
    Leave them as Media 100 clips. They’ll play in Quicktime as long as you have the codec installed. You might save a bit of space transcoding to something like H.264 but it’s unlikely to be worth the time and effort unless you want to make the clips totally portable.
