Activity Forums DaVinci Resolve Archiving Options in Resolve 14
  • Archiving Options in Resolve 14
    Posted by Andrew Akada on June 14, 2018 at 7:25 pm
    I scoured the manual and Lynda but I couldn’t find an exact answer so I apologize in advance if this is a RTFM situation but I just cut a project using Resolve 14 and I’m trying to pass along the archive to a colleague. However, I’m trying to limit the size of the overall archive for the sake of expediency and I realize that all of my dailies were included in the archive as well (since they’re organized in bins within the project itself).
    My question is this: When you archive a project in Resolve, is there any option or function that will limit the included media files in the archive to clips/footage used exclusively in the timeline(s) or is the only way to limit the size of an archive to retroactively create smart bins and collect the timeline media manually? Any insight into this would be greatly appreciated. Thanks!
    Jay Walsh replied 7 years, 1 month ago 3 Members · 3 Replies
  • Tero Ahlfors
    June 15, 2018 at 8:05 am
    You could use the media management tool to trim/transcode your footage and then export a project file to go with those. Check page 495 and forwards in the January 2018 manual.
  • Andrew Akada
    June 17, 2018 at 11:17 pm
    Thanks, Tero! I just tried the method RE the manual but when I copy the media the folder structures aren’t retained (even when I select the option to recreate sub-directories up to 5 levels deep). All of the media is just dumped into a single folder. I’ve tried it a few times to see if I was fudging the settings but the outcome appears the same no matter how the cookie crumbles. Would the project file be able to recreate the entire folder structure or would I have to relink the clips one by one in the media pool?
  • Jay Walsh
    July 15, 2019 at 2:57 pm
    Hi, I was just looking for this myself… solved it.
    Go to your Home Screen.
    Right click or CONTROL click the project you wish to save.
    In the drop down menu, select ARCHIVE
    Navigate to the folder you want to save your files.
    Click SAVE.
    You’ll get a .DRA file… this includes your project, all associated media, AND any LUTS you previously applied.
    Hope this helps.
