Activity › Forums › Apple Final Cut Pro Legacy › Archiving FCP projects
  • Archiving FCP projects
    Posted by Ran Moncaz on January 11, 2014 at 8:52 pm
    So… out of hard drive space, and time to clean up…
    When I begin to work on a project I copy the camera memory card onto the hard drive, and then go through the Log and transfer process.
    When I finish working on a project, but still want to keep it available for further work, it seems like a waste of space to keep both the original card copy, and the capture scratch folder.
    Any thoughts?
    Shane Ross replied 12 years, 8 months ago 3 Members · 2 Replies
  • Daniel Sametz
    January 12, 2014 at 2:13 am
    I would erase the capture scratch and leave the card files. If you need to use the project again do L&T.
    There could be problems if you reconect but if you L&T with FC then you should be ok.
  • Shane Ross
    January 12, 2014 at 2:24 am
    You should never keep the camera masters and the imported media on the same hard drive. If you lose that drive, all you media is gone.
    When shooting tapeless, you need multiple hard drives. Drives you archive your camera masters to, that you keep and store. Best to have two sets of those drives. Them your media drive that you import the footage to and work from. When done you can trash those files, as you can always reimport. And just archive audio files and still and graphics.
    I also choose to archive the media used in the final locked piece. Media manage the footage with handles to yet another drive (cheap ish USB). Because I always reuse my media drive, but often have to revisit old projects.
    Shane
    Little Frog Post
