Activity Forums Panasonic Cameras Archiving, again!
  • Archiving, again!
    Posted by Frank Nolan on May 16, 2006 at 9:03 pm
    I know this has been discussed here a lot but here we go again.
    If just using the P2 cards (no FS, P2 store, cineporter etc.), can you take an 8gb P2 card into a PCMCIA slot on a G4 and then burn the contents folder and lastclip.txt file directly to a Dual/double layer 8.5gb DVD as well as copying to a hard drive?
    This would in effect give you a low cost (about $2) storage and archive solution. Shooting in 24pn that would be about 20 minutes of footage so it would cost about $6 an hour for storage of DVCPro HD footage as oppossed to $30-40 for a tape.
    Any Pro’s, Con’s?
    Barry Green replied 20 years, 4 months ago 2 Members · 1 Reply
  • Barry Green
    May 17, 2006 at 2:05 am
    Yes you can do that. Only con is that burning DL DVDs isn’t the fastest procedure.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
