Activity › Forums › Adobe After Effects › Archiving AE Projects
Posted by Michael Mcswain on August 23, 2007 at 6:32 pmIs there no archive/media manage feature in After Effects 7?
Michael Mcswain replied 19 years, 1 month ago 3 Members · 3 Replies -
Roland R. kahlenberg
August 24, 2007 at 12:35 amFiles->Collect Files is what you want. But before you get there, you may want to first clean up your project.
For that there are Files>Remove Unused Footage. Then there is Files->Consolidate All Footage. This one removes redundant footage items and relinks those items that have been removed.
The use Files->Reduce Project. For this, select comps that you want to retain before selecting this option.
Your final procedure is to select Files->Collect Files. All the routines are undoable.
Someone should wrte a script to run through the process with a SaveAs (for backup purposes) as the first routine.
HTH
Roland Kahlenberg
https://www.broadcastGEMs.com – Adobe After Effects project files
https://www.myspace.com/rorkrgbspace
