  • Posted by Dan Archer on January 8, 2009 at 5:10 pm
    I am working with a lot of P2 and EX3 files. Its time to archive some thing and i want your opinion.
    Should i archive just the QT files made on import or should I archive the original P2 files as well.
    What do you do.
    A cut is a cut & a dissolve is a disolve, and not just anybody with a system is a pro.
    Shane Ross replied 17 years, 7 months ago 2 Members · 3 Replies
  • Shane Ross
    January 8, 2009 at 5:12 pm
    Archive the original P2 card dumps, not the QT files. The P2 offloads are your master tapes. Archive the master tapes.
    Shane
  • Dan Archer
    January 8, 2009 at 5:23 pm
    When you unarchive, do you just reimport the footage from the master P2 files and they link up. That would be great.
  • Shane Ross
    January 8, 2009 at 6:20 pm
    Watch the tutorial I made for P2 Import…
    P2 Workflow with FCP 6
    If you want to reimport the footage, simply reconnect the archive drive, highlight the clips and choose BATCH CAPTURE. It will reimport the footage, and heed all the clip renaming and IN/OUT points you might have set.
    Mighty slick.
    Shane
