archive two projects cut from the same events.
I have edited two projects, with footage sourced from the same events. Both projects use some of the same footage, and some unique footage. Now I want to duplicate both projects, using “+ used clips only” onto an external drive for archiving, but I don’t want to end up with multiple copies of the same footage on the drive. I tried duplicating both projects separately, then merging the EVENTS folders, trashing the doubled up clips, then relinking the lost footage from the project whose event I trashed to the event from the other project, but I keep getting an error message saying “Incompatible file : The original file and new file have different audio source and channel counts.” This is despite the fact that the deleted file, and the one I’m trying to replace it with both seem to be exactly the same, and I would have thought, were just copies of the original file FCPX transcoded when I imported it. Is there a simpler way to do what I’m trying to do, or any way at all? Generally I love FCPX, but this one little issue has been bothering me for days. Any help would be appreciated, Thanks very much.
Sam
