Activity Forums Square Box CatDV Archive Status and Cache-A
  • Archive Status and Cache-A
    Posted by Whitney Sickels on July 31, 2012 at 2:05 pm
    Hi there,
    I see many people have been having issues with Cache-A, but I have a couple of questions that can hopefully be answered. (I just asked for an upgrade so maybe that will fix them?)
    I’ve been concerned about the differing messages in my archive summaries. It is not the same on every clip after archiving the media. It says either: ‘Already copied to…’, ‘Archived to…’ and ‘Copied to…’ followed by the serial number of the first LTO I put in (more on that below) and then either ‘currently on tape’ or ‘currently offline’. I assume the ones that say currently offline is from any LTO tapes that are not currently in the deck? But why are these statuses different when I do the same exact thing each time? (Just select clips and Archive media files…)
    Once you “Archive” the files how do you tell it to write it to the LTO?
    This morning I ejected the LTO that was in the deck, with nothing on it apparently, then pushed it back in. It then started transferring files and became full. It named it by it’s serial number (AC38E6RAR4). Then it ejected the tape and asked for another. I put another LTO in and “Initialized” it. However, it named it the serial number from the previous tape followed with ‘_2’. Then, that LTO filled, asked for another and stopped (not enough left to fill) And again, it named this one the same serial number as the first LTO followed with ‘_3’. I checked CatDV and there are no records with LTO ‘_2’ in the Archive Tape, Details or Summary info. Only AC38E6RAR4 and AC38E6RAR4_3 (the LTO currently in the deck). Yet, when I ‘Check Archive Status’ in CatDV of one claiming to be on AC38E6RAR4_3 it tells me it’s on ‘_2’. What is the deal? And why isn’t it correctly naming it the serial number that is on the actual LTO?
    I have many more questions but am still trying to wrap my head around this and have a tech guy helping tomorrow. Any help on this is appreciated!
    Currently on Version 2.0.22 Cache-A
    9.0.6 CatDV
    Tom Goldberg replied 12 years, 9 months ago 5 Members · 17 Replies
  • 17 Replies
  • Bryson Jones
    July 31, 2012 at 3:14 pm
    No ideas on the tape ID thing, let’s see what the Cache-A guys have to say.
    The official word on the copied vs archived is this. “Copied means it’s copied it to the vtape. Archived means that additionally it has received confirmation (by reading the transfer log file) that the file has successfully been written to tape. You won’t always get the latter, for example if you archive files by copying them to the vtape, then immediately close the CatDV catalog before it’s written to tape.”
    This is from Squarebox and should explain a lot. Tape moves slowly, the confirmation takes a while and since the unit writes through the client app, the catalog can’t close before the whole operation is done.
    The archive, however is most likely fine since it made it to the vtape.
    bryson
    bryson “at” northshoreautomation.com
  • Rolf Howarth
    July 31, 2012 at 4:58 pm
    The Cache-A device is supposed to automatically write files to tape once they’ve been copied to vtape, so to archive a file CatDV copies it to the vtape. If you quit CatDV immediately then the archive status will be “Coped to tape XYZ’ (where CatDV gets the current tape identifier from the Cache-A device), but if you leave it running long enough for CatDV to get confirmation from the Cache-A transfer log then it updates the status to say “Archived to tape XYZ”.
    It says “currently on vtape” if the file exists in the vtape folder (ie. the hard disk cache that Cache-A uses). The file normally stays on the Cache-A hard disk until you load a new tape into the drive.
  • Tom Goldberg
    July 31, 2012 at 9:38 pm
    Hi Whitney,
    I’m not sure why these files weren’t going to tape as you sent them, but that is the root cause of your issue. You had apparently pushed more than 3 TB of data to our VTAPE but the Cache-A did not start actually archiving until you reinserted the tape, whereupon we did what we normally do with more data than what would fit on a tape – tape spanning. When tapes are spanned, they all form a single logical volume and thus are named with the naming convention you noted (i.e. first_tape_name, first_tape_name_2 and so on).
    Unfortunately, CatDV does not at this time accommodate spanned sets, so although apparently all your data is safely on tape, CatDV doesn’t know which volume it landed on.
    You can either keep this 3 tape spanned set as it is and use the Cache-A’s search function to restore content when you need it or, if you want CatDV to remain in charge, re-archive your stuff to individual tapes.
    The CatDV Archive interface nicely reports how much space you’ve used on each tape as you go – in your case, it must have constantly been reporting 0% which should have been a good clue that something wasn’t quite right! If you start archiving to a new tape, note whether those items are actually getting written to tape – you can also easily tell from the Cache-A user interface by noting the Transfer Summary. If it still doesn’t seem to be happening properly, let us know and we’ll look into what might be causing your problem. Don’t forget that your Cache-A share is probably close to full from that last spanned set so you’ll need to be erasing data to make room for new archiving.
    Tom Goldberg
    Cache-A Corporation
    602 Park Point Drive
    Golden, CO 80401
    mailto:tom.goldberg@cache-a.com
    https://cache-a.com
  • Whitney Sickels
    August 1, 2012 at 9:13 am
    Ok – now I understand the difference! Thanks!
    So I need to select the clips, ‘Archive Media Files’ and then leave CatDV open so it can then copy to LTO. Is there a specific setting we need to let it know to “automatically” transfer to LTO or once it’s on vtape it knows to copy over? Should I re-open the catalog to see if the status has changed from Copied to Archived or is there a better way of knowing once it’s on LTO? (Check the Cache-A Tape Directory?)
    What should the workflow be like? Do I archive files (daily) as I create them, check the LTO periodically and once it’s full, delete the contents of the vtape, and then put in a new LTO? Or do I have to wait until I have 1.5 TB worth of footage on the vtape and then put a new LTO in?
  • Whitney Sickels
    August 1, 2012 at 9:19 am
    Hi Tom,
    Thank you for your response – very helpful.
    We would prefer not to span the tapes and re-archive to individual tapes. What is the best way of doing this? Is there a way to tell it not to span or do I need to clear the vtape and essentially re-archive everything via CatDV?
    Also, what is this archive interface in CatDV that lets me know how much space is on each tape that you speak of? 🙂 I see the information on Cache-A in Tape Information/Summary, but not in CatDV.
    Cheers!
    Whitney
  • Tom Goldberg
    August 2, 2012 at 12:57 am
    Hi Whitney,
    The best way to avoid spanning is to not put too much on a tape. You can turn it off under System Tools page > Settings tab > Multiple Volumes off. However, if you overfill a tape in this case, you end up with a tape that has no TOC – not good either.
    In the CatDV “Archive Media Files” dialog there is a line that displays the Current Tape and in parentheses after the Media ID of the tape is a percentage displayed (45.6% used). To be safe, I would tend to move on to another tape once you get above 90%.
    Tom Goldberg
    Cache-A Corporation
    Golden, CO 80401
    https://cache-a.com
  • Whitney Sickels
    August 2, 2012 at 8:13 am
    Ah yes! Thanks for the help and advice, much appreciated.
  • Whitney Sickels
    August 22, 2012 at 1:06 pm
    Hi again,
    I deleted the VTAPE and am re-archiving everything to avoid tape spanning. However, I just checked some and they say “Archived to (NEW TAPE NAME)”. Sounds good. But when I “Check archive status” it says it’s on the old (spanned) tape number. How do I get it to reference the new tape number?
    I checked the LTO and as of now it has about 800 MB lost space… and growing as I continue archiving. What is causing this? It’s Cache-A format (tar).
    2.1.16 Cache-A
    9.0.6 CatDV
    Cheers!
  • Rolf Howarth
    August 22, 2012 at 2:05 pm
    Check Archive Status uses the Cache-A API to query the tape a given file is stored on. Unfortunately I believe the API only returns the first tape, whereas it would be more useful if it returned all the tapes, or the last tape.
  • Whitney Sickels
    August 22, 2012 at 2:23 pm
    OK, thanks. That’s a shame.
    On another note, I just checked the ones I (re)archived yesterday and there seems to be an issue. On some of them, on the Archive details they say ‘Copied to’ (as opposed to ‘Archived to’), even though they all said Archived before I left work yesterday (and I left CatDV open to make sure it had time to copy to LTO). However, I checked the LTO and the file seems to be there. I was told Copied means they are on vtape and Archived means they are on LTO. So why do some still say copied when they are on the LTO? I checked a few files that are marked as copied and they are also on LTO.
    After the ‘Archived/Copied to’ there is a semi-colon and something that either has said “currently on vtape” or “currently offline”. What is this referencing? If the former, then it’s still on vtape and the latter it is no longer on vtape?
    Cheers.
