Activity Forums DaVinci Resolve Archive Options (Render Cache & Optimized Media)
  • Archive Options (Render Cache & Optimized Media)
    Posted by Max Smith on October 17, 2016 at 3:29 pm
    Hello there,
    While archiving my project in Resolve I now am given these two options in he form of check boxes before I start the archive process.
    I was wondering if someone could shed some light on what the function of each option is, and if I should select both options when archiving. I would assume it is a case by case basis, however I’m not sure what is actually occurring when I select each option and whether or not I need them.
    Thank you for your help.
    Max
    Max Smith replied 9 years, 11 months ago 2 Members · 2 Replies
  • Marc Wielage
    October 18, 2016 at 11:28 pm
    If the project is already done, I don’t see why you need Optimized Media or the Render Cache. You can always rebuild each of them later. If the Render Cache is small, I guess that wouldn’t be too much of a problem.
  • Max Smith
    October 19, 2016 at 2:51 pm
    Ok awesome! That was what I was thinking but I wasn’t quite sure. I just wanted to double check that I wouldn’t be messing anything up by not selecting either option. Thank you very much for the info and reply Marc!
    -Max
