Activity › Forums › Apple Final Cut Pro Legacy › Archive .mov files to blue ray disc
  • Rafael Amador
    January 20, 2011 at 8:42 pm
    That will depends on what kind of stuff you want to stock.
    If it is footage or movies that will be further processed, you need to store with the less compressed format you can afford and you may use the Blue-ray for as data disks.
    If the stuff won’t suffer further processing and you want to archive for high quality display or distribution, H264 is the codec. With the H264/.mov you can build self-playable BR disks (you will meed to author the disk) or archive them as data-disks too.
    rafael
    http://www.nagavideo.com
  • Lavoy Shepherd
    January 20, 2011 at 9:55 pm
    I just want to back up .mov files from the SDHC cards from my camera.
    I should be able to put 25 gigs per Blu Ray disc
  • Rafael Amador
    January 20, 2011 at 10:32 pm
    [Lavoy Shepherd] “I should be able to put 25 gigs per Blu Ray disc”
    I use 50 GBs BR disks.
    Rafael
  • Lavoy Shepherd
    January 21, 2011 at 12:18 am
    That’s cool how is the best way to do it?
  • Rafael Amador
    January 21, 2011 at 12:27 am
    You need an external recorder and Toast.
    Select Data BR, drag and drop.
    rafael
  • Lavoy Shepherd
    January 21, 2011 at 1:06 am
    Thank You. I have both I will give it a try.
