Activity Forums Apple Final Cut Pro Legacy Archive Final Sequence with 1 sec handles
  • Archive Final Sequence with 1 sec handles
    Posted by Mike Colao on January 16, 2009 at 3:22 pm
    Hey All,
    I’m trying to Archive a FINAL master sequence in Final Cut Pro 6.0.5
    What I’d like to end up with is a project of my current MASTER sequence with master clips of 1 sec. handles (essentially doing what AVID calls a CONSOLIDATE)
    The entire project Media is 90GB’s and when I select the sequence go to media manager select COPY, set handles the bar says it will COPY 70GB?
    Im a bit confused as to why it’s giving me such a high number. I suspect the resulting media should be around 10GB.
    Any thoughts?
    -MIKE
    Mike Colao replied 17 years, 7 months ago 1 Member · 1 Reply
  • Mike Colao
    January 16, 2009 at 3:32 pm
    Nevermind! I figured it out.
    I selected right-clicked the sequence and selected MAKE CLIPS INDEPENDENT. Then with the sequence still selected went to media manager and selected COPY from the menu and all is well.
    -MIKE
