Activity Forums Adobe After Effects Expressions Architectural / Blueprint
  • Architectural / Blueprint
    Posted by Henry Gaunt on June 17, 2009 at 8:27 am
    Hello,
    I’m wanting to create a background of lines being drawn that look like car blueprints. However, I don’t have any blueprints to work with, nor can I draw!
    I have zero ability when it comes to expressions. I was just wondering if there is an expression/setup I can use, to random animate ‘blueprint’ looking lines slowly revealing?
    It’s only for movement in the background and will be about 50% opacity. It’s an 8 minute video, so randomness is key.
    Any suggestions would be helpful!
    Thanks.
    Henry
    Koby Goldberg replied 17 years, 2 months ago 3 Members · 2 Replies
  • Filip Vandueren
    June 17, 2009 at 1:56 pm
    I’d create some Shape layers with multiple straight lines, then add a stroke.
    You can add dotted line strokes which is also nice for a blueprint looks,
    Then add path offset, you can then animate the strokes very easily using start/end/offset.
    No expressions needed, just check the manual for shapes.
    And don’t rely on expressions to do everything magically for you, sometimes you do need to work to get results…
  • Koby Goldberg
    June 22, 2009 at 11:52 am
    Henry,
    You could actualy can do this using an expression, and the “CC Time Blend” effect…
    1. Create a new composition, create a Solid in it, and make a small
    round mask on that solid (i.e.: small circle on a transparent background). Make the size of the circle as your desired Blueprint line width .
    2. give that solid a wiggle position expression, something like:
    wiggle(0.1,300)
    so you will have this small circle moving on a random path.
    3. Insert this composition to your main comp,
    and give it the “CC Time Blend” effect, with Transfer = Add, Accumulation = 100%
    And that’s it !
    Play with the wiggle paramethers to achieve a different stroke path.
    p.s.: The “CC Time Blend” effect needs to be rendered always from the beginning of the timeline, so always before you make a RAM preview, clean the cache by Edit -> Purge -> All. (or else you could get strange results in the RAM preview)
    Koby.
