Activity › Forums › VEGAS Pro › Architect question
  • Edward Troxel
    December 30, 2007 at 3:54 am
    You have to set the IN *and* OUT points. You may need to add the media an additional time for this “chapter”.
    Edward Troxel
    JETDV Scripts
  • Randall Raymond
    December 30, 2007 at 4:44 pm
    I have 21 shorts playing encoded as one mpg with chapter markers. The ‘Play all’ button works just fine.
    Are you saying I need to insert the same mpg file 21 times to have the in and out points work for each of the 21 buttons?
  • Adam Rose esq.
    December 30, 2007 at 5:47 pm
    usually chapters play for partic position to the end of the movie. since you want to return to the main menu after each chapter, you have to add the movie multiple times, and position the IN & OUT points for each one – the movie will only actually be on the disk once.
  • Adam Rose esq.
    December 30, 2007 at 5:50 pm
  • Randall Raymond
    December 30, 2007 at 5:55 pm
    Yes, thanks – I think I got it – seems to be working fine but what a pain!
  • Randall Raymond
    December 30, 2007 at 7:15 pm
    Right. I can see the logic of it now. The 21 links point to in/outs on 21 copies (actually references) to the same media.
  • Randall Raymond
    December 30, 2007 at 9:55 pm
    OK – starting the render – each of the in/out references to the main movie is producing it’s own audio track that needs to be rendered to AC3 – is that common or correct – or did I miss something?
  • Adam Rose esq.
    December 30, 2007 at 10:34 pm
    don’t know why it’s doing that, but never had it before………
    you’re just lucky
  • Randall Raymond
    December 31, 2007 at 2:55 pm
    [Adam Rose Esq.] “you’re just lucky”
    I guess – disk is working perfectly. With the 21 ac3 audio encodes – there’s just 34megs of space left on the disk. That was close!
