Activity Forums VEGAS Pro architect pal dvd bad quality
  • architect pal dvd bad quality
    Posted by Ron Bakker on April 23, 2011 at 7:39 am
    I dont know what I am doing wrong but I find the finished product I’m getting from architect is not very good. Between vegas and dvd I lose a lot of detail. First I just rendered out my project out using the pal template which I played before I put it through architect and found the quality was already pretty average to poor then when I finished the burn and played it I found the quality even worse. Then I tried rendering out my project as an hdv which looked good but then after architect it looked bad again. can’t help but think I have a setting wrong on Architect. The output I’m getting is substandard to my you tube videos which very much surprises me as the dvd file is 4.1 gigs. I did a search but didn’t really find any links covering the same thing.
    Cheers.
    Pentium 2.4 quad|Asus P5G41C-M LX mobo|2 gig corsairs 6400 ram|Corsairs 630 power supply|Gigabyte 8800gt|2x seagate 500gig Hd’s|Lg dvd burner|windows7 premium , SV9E
    Ron Bakker replied 15 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    April 23, 2011 at 1:54 pm
    It sounds like you are expecting SD PAL video at 720×576 to look as good as HD video at 1920×1080. This isn’t going to happen because you have 5x less resolution. Make sure that you render to MainConcept MPEG2 using the DVD Architect PAL Widescreen video stream template. Before you render, set your project preview to Good (Full) so that it will be picked up by the render template which uses project properties by default. Then render your audio as Dolby Digital AC3 Pro. This should give you as good results as possible for PAL SD.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ed Baldwin
    April 23, 2011 at 6:09 pm
    [John Rofrano] “Before you render, set your project preview to Good (Full) so that it will be picked up by the render template which uses project properties by default. Then render your audio as Dolby Digital AC3 Pro.”
    jr, I did not think the Preview quality had any effect on the rendered video. In Help “Click the Preview Quality button and choose a setting from the menu to change the quality and resolution for rendering your video preview.
    This setting is used for previewing only and has no effect on the final rendered video.” Has something changed or am I missing something?
    – Ed B
  • John Rofrano
    April 23, 2011 at 8:45 pm
    [Ed Baldwin] “This setting is used for previewing only and has no effect on the final rendered video.” Has something changed or am I missing something?”
    Well… I noticed that when I have my preview set to (Auto), render uses auto mode, if I set my preview to (Quarter), render uses quarter mode. This is just my observation so I assume it might have an affect on render quality but maybe it doesn’t. Maybe it always renders Full. I just did a few more render tests and they all looked the same so maybe it doesn’t affect the final render.
    ~jr
  • Ed Baldwin
    April 23, 2011 at 9:02 pm
    [John Rofrano] ” if I set my preview to (Quarter), render uses quarter mode. This is just my observation so I assume it might have an affect on render quality but maybe it doesn’t. Maybe it always renders Full. I just did a few more render tests and they all looked the same so maybe it doesn’t affect the final render.”
    How did you determine what render quality was being used? If you have ‘Use Project Settings’ set in the Video rendering quality in the project tab of the render setup the render will use what you set in in the ‘Full-resolution rendering quality’ in the project properties.
    Ed B
  • John Rofrano
    April 23, 2011 at 10:07 pm
    [Ed Baldwin] “How did you determine what render quality was being used?”
    I was looking at the preview window during render. It will show you the quality it is using. It appears that this has no bearing on the actual render. It just seems to affect the preview.
    ~jr
  • Ed Baldwin
    April 23, 2011 at 10:44 pm
    [John Rofrano] ” It appears that this has no bearing on the actual render. It just seems to affect the preview.”
    Yea, that is what ‘Help’ says: “This setting is used for previewing only and has no effect on the final rendered video.”
    I have always set the render quality setting to max (31) and ‘best’ as the only gain would be a shorter render time.
    -ed
  • Ron Bakker
    April 24, 2011 at 9:48 am
    Thanks John,
    I guess I am just trying to get the same quality as I see on production dvd’s, I think I will have to live with the results as I have done exactly as you suggested. I might look at a blue ray burner soon.
