Activity Forums VEGAS Pro Architect 5.0 Aspect ratio control in optomize disk dialog
  • Architect 5.0 Aspect ratio control in optomize disk dialog
    Posted by Pete Locascio on January 24, 2009 at 11:19 pm
    When adjusting the recompression settings in the optomize disk dialog, I choose the 16:9 video format. The book says that I should get the widescreen format on a wide screen TV, which I do. It also says that the picture should be letter boxed on a 4:3 TV. There is no letter boxing and the picture is vertically stretched. My project properties are set correctly. Any ideas? Thanks!
    Rob Strobbe replied 17 years, 7 months ago 2 Members · 1 Reply
  • Rob Strobbe
    January 25, 2009 at 4:54 am
    If it appears correctly on a widescreen television, then I would suspect that the 16:9 flag was set correctly.
    Do other widescreen DVDs played on your 4:3 television get letterboxed or stretched? If they also get stretched, then check through your DVD player’s setup menus — either for a setting that tells it what kind of TV it’s hooked up to or one that tells it what to do with widescreen content.
    Rob
