Activity Forums Adobe After Effects Arbitrary Maps
  • Arbitrary Maps
    Posted by Lazlo Hollyfeld on April 11, 2006 at 10:04 pm
    Adding a repeat post, sorry for the inconvenienec.
    Does anybody know how to get the Arbitrary Map to function properly in the parameters for the Glow effect?
    Arie
    Spaceman replied 20 years, 5 months ago 3 Members · 2 Replies
  • Christopher R. green
    April 12, 2006 at 1:02 am
    Sorry about the lack of reponse, Arie.
    I’m also sorry that I probably won’t be able to give an adequate answer.
    The thing is, I haven’t used an arbitrary map since Star Trek VI (1991). As I recall, these are created usually by using the curves editor in Photoshop. Presumably AE at one point supported the loading of such a map file for use in the glow effect as well as the PS Arbitrary Map filter. I am working in AE 6.5 still, and these functions are totally dead. When “Arbitrary Map” is selected in the glow effect, you are supposed to be presented with a file open dialog. But no. Though it could be argued that this is an ‘outdated’ technique, this is pretty inexcusable. I guess you’ll have to do something like double up the image and use the curves adjustment filter, then the glow, then composite that over your original.
    hope this helps …
    cg
  • Spaceman
    April 12, 2006 at 11:36 am
    SPACEMAN opens a dialog by hitting ‘options’ on the Glow and Aritrary Maps fx.
