Activity Forums Avid Media Composer Arabic in title tool
  • Arabic in title tool
    Posted by Tel Jaba on November 28, 2010 at 9:54 pm
    Hello guys
    I am working with Avid Media Composer and I need to create subtitles and credits in Arabic using the title tool. so far when trying to type in Arabic it type from left to right and I get squares, not letters,
    what do I need in order to be able to use the title tool in Arabic and to type right to left?
    Many thanks
    Randy Pfeiffer replied 15 years, 9 months ago 3 Members · 3 Replies
  • Paul Harrington
    November 29, 2010 at 6:25 am
    We created all our Arabic script in Photoshop. We found that a lot easier workflow…Harry
  • Tel Jaba
    November 29, 2010 at 8:18 am
    Thanks a lot Paul. I know Photoshop is an option but I thought it would be easier to make the changes within Avid without having to jump between two different applications. I know that a friend of mine can type in Arabic, she said she has TitleDeco Pro which has a plug in for Avid that allows it to type right to left.
    I’ve downloaded TitleDeco… but still have the same problem
    any ideas?
    there used to be also a very simple program that I worked with once whcih you copy and paste your text from into Avd title tool and Avid sees it as a picture so it works fine with Hebrew and Arabic, but I cant remember what that program is called!!
  • Randy Pfeiffer
    December 1, 2010 at 7:15 pm
    If you are using Marquee title tool, after typing a character, right-click in window and in pop-up menu select “direction” and select “right-to-left”
    HTH
    Cheers,
    Randy
