Activity › Forums › Adobe Premiere Pro › Appyling default transition to ENDS of clips
  • Patrick Kilchermann
    November 13, 2013 at 3:45 pm
    Okay Casey, that helps a lot. I can’t switch in the middle of this project obviously, but it sounds like I should add that to the purchase queue (right after one more T3i, hehe).
    One question about Multicam… I shot this project with 2 cams. But CS5.5 seems to work okay, I just have the base video layer visible, and an invisible video layer above it where I put the second angle. I sync up both sets of footage when import them, and when I want to use the second angle, I slice them both, and drag the second angle onto the base layer (after I move the base layer to another invisible “junk” track).
    Is that not how everyone else does it?
  • Casey Culver
    November 13, 2013 at 4:59 pm
    Yeah, there are definitely ways of simulating a multicam setup – especially if you’ve only got two or three tracks that you’re cutting together. I’m working on a music video today where I’ve got 16 tracks playing at once (see below) so if I had those bad boys stacked up and was trying to cut sections out here and there, it’d be quite challenging… And not that you should, but you could upgrade and immediately start working in CS6 or CC..
    November 13, 2013 at 5:09 pm
    Wow! That feature and especially your project, are amazing! GOOD LUCK on that sucker!
Page 2 of 2
